Template for Nova Cannon - Ordantius Armageddon
 Post subject: Template for Nova Cannon - Ordantius Armageddon
PostPosted: Mon Oct 01, 2018 7:10 am
Hey Guys,
Probably being blind but apparently the above is in WD 191 however, I can’t seem to find it in that issue. Does anyone have a template they could share with me please?
Thanks,
Rob.
 Post subject: Re: Template for Nova Cannon - Ordantius Armageddon
PostPosted: Mon Oct 01, 2018 12:44 pm
it was a paper card that was bundled in the issue so no surprise you can't find it. I'm not sure it was significantly different than the 40k blast template but old age has set in ...
PostPosted: Mon Oct 01, 2018 12:51 pm
Interesting - so it wasn’t attached as such with the ordantius cards.
PostPosted: Mon Oct 01, 2018 6:56 pm
What size template was that - the smaller one?
PostPosted: Mon Oct 01, 2018 9:38 pm
I will see if I can find that wd. The trick will be where did I put the template if it was a separate piece.
PostPosted: Tue Oct 02, 2018 6:40 am
Thanks!
PostPosted: Wed Oct 03, 2018 8:28 am
Well the white dwarf definitely says the template is on a separate card stock. Where on earth have I put it. LOL.
It would help if I could remember what it looked like size wise. Damn old age.
PostPosted: Wed Oct 03, 2018 10:09 am
Tell me about it!
PostPosted: Wed Oct 03, 2018 2:06 pm
AFAIK it is a 3cm round template …
PostPosted: Wed Oct 03, 2018 2:35 pm
AFAIK?
PostPosted: Wed Oct 03, 2018 3:05 pm
As Far As I Know … don't know if there were any "updates" to that … Certainly have not found any.
PostPosted: Wed Oct 03, 2018 11:31 pm
My epipedia of 6mm knowledge and wisdom, L4, tells me that that it is a 3cm round template.
Page 55 of the netepic core rules has a 3cm template.
Poor quality copy attached. Its the small template.
PostPosted: Thu Oct 04, 2018 6:23 am
Thanks! Do GW currently do a similar template?
PostPosted: Thu Oct 04, 2018 1:07 pm
Well thank you Lyle ! ;D :whistle
PostPosted: Thu Oct 04, 2018 1:08 pm
You mean for AT18 ? Not AFAIK ... :-\
