Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2, 3  Next
Net Epic Gold errata document
 Post subject: Net Epic Gold errata document
PostPosted: Thu Sep 04, 2014 7:02 pm
This is the pdf for the errata document for gold.
This free standing document can be used by those whom have already printed the gold books.
It will also server as a template for correcting the original Gold files, which will be the next step.
Edit: latest file dated 4/26/15.
Net Epic Gold correction document.pdf [118.89 KiB]
Downloaded 187 times
 Post subject: Re: Net Epic Gold errata document
PostPosted: Thu Sep 04, 2014 7:53 pm
Nice work!
A couple of questions about the Librarian powers.
Purge: I'm assuming LOS to target is not required, is this right?
Force Dome: can units within the force dome fire out of it!
Proud to be described by CyberShadow as Tactical Command's "...biggest threat in recent times..."!
Clickable links for Epic hijinks:
PostPosted: Thu Sep 04, 2014 7:58 pm
Presumably the Eldar Titan gets the reactor removed from the front as well?
I was also wondering about the leg saves for this location, they are shown as 2+ on the document, but I thought this would be a 1+ save as this is where the legs meet and as such would be stronger than a standard leg location.
PostPosted: Thu Sep 04, 2014 11:19 pm
The Bissler wrote:
Nice work!
Purge, no LOS required.
Force Dome. Units may fire normally.
PostPosted: Thu Sep 04, 2014 11:21 pm
Applies to Eldar titans.
Save remains at 2+. Joints tend to be weaker, not stronger than a solid shaft with no joints.
PostPosted: Thu Oct 16, 2014 1:54 pm
There's an error in stats for CSM HQ bike, caf is noted +2 instead of +3 ;)
And I'm a bit concerned about multilasers, they are not AA and are placed behind Warlord carapace, I do not understand why they're costed 100 points ?
PostPosted: Thu Oct 16, 2014 4:00 pm
Thanks for the error notification. I have yet to sit down at take up the task of updating the actual gold documents, but I can fix the PDF easier. :)
I thought it was the AA multilasers that were 100 not the regular ones?
One more thing to check.
PostPosted: Thu Oct 16, 2014 4:08 pm
Official AA titan weapon is the Cerberus AA. MultiLasers are small cheap rear carapaces weapons and never get the AA ability unless I did not see a modification about this.
PostPosted: Sat Jan 10, 2015 9:02 pm
The latest errata document for net epic gold is now available for download at the Epicentre:
http://www.netepic.org/uploads/2/2/1/0/ ... cument.pdf
PostPosted: Mon Jan 12, 2015 11:30 pm
I have completed and made available the latest updated netepic gold files here:
http://www.netepic.org/netepic.html
Please note I have kept the original files, so look with the ones that have "with errata" in their file name.
I have also updated the master changes PDF also available in the same link correcting many errors within the original file.
Enjoy!
PostPosted: Tue Jan 13, 2015 12:16 am
You've been busy! Excellent!
:spin
PostPosted: Tue Jan 13, 2015 2:11 am
:spin
Yes I have. ;)
I hope to learn more Indesign, that may open a lot of possibilities for us. :)
PostPosted: Wed Jan 14, 2015 3:02 pm
Many thanks Peter for the correction document :)
PostPosted: Wed Jan 14, 2015 6:08 pm
No problem, I can now add/subratract/modify anything else that is need on the master errata document or original gold books and have them available at the Epicentre in very quickly now.
We can now have updated versions very easily.
PostPosted: Thu Jan 15, 2015 9:34 am
Sounds cool Peter.
