Post new topic Reply to topic  [ 1023 posts ]  Go to page Previous  1 ... 60, 61, 62, 63, 64, 65, 66 ... 69  Next
 Post subject: Re: Vanguard Miniatures
PostPosted: Sun Feb 11, 2018 9:44 pm
Blast from the past!
Annihilation Commander Set - £8.50
Another blast from the past Troublemaker games archive model, 28mm scale Annihilation commander set.
Set contains:
1 x body A
1 x body B
2 x heads
2 x left arm
2 x right arm
Actual height approx. 30mm
http://vanguardminiatures.co.uk/shop/an ... ander-set/
PostPosted: Mon Feb 12, 2018 2:15 am
Hey, sorry if this has been asked before - but the Skinnerz set A and B - are they just different poses or are B a later, slightly higher quality sculpt?
Warmaster Armies: Chaos, High Elves, Dark Elves
Warmaster WIP: Empire, Vampire Counts, Lizardmen, Kislev etc.
PostPosted: Mon Feb 12, 2018 3:35 pm
What as the dimensions of these guys ? :sos :-\
PostPosted: Mon Feb 12, 2018 9:44 pm
I've just ordered some of these so should be able to answer (although someone please feel free to correct me!)
The A pack included just hand weapon and pistol. The B pack contains some of these, but also guys with a rifle/machine gun.
Have just checked my pack - of the 40 orks 20 of them are holding machine gun or a heavy machine gun, the other 20 are I believe the same as the A pack.
As for quality, I can't see any difference between A and B - but they are all excellent! :)
PostPosted: Mon Feb 12, 2018 10:39 pm
I haven't noticed any real quality difference in the sculpts in terms of detail, but the A sculpts are somewhat flimsier due to their outstretched arms and slim weapon handles. There's a risk of bending or snapping if you are careless. I prefer the B sculpts of the melee skinnerz for that reason. Plus they are easier to fit on the base without getting in eachother's way!
PostPosted: Mon Feb 12, 2018 10:40 pm
Infantry set A contain all melee weapons but suffered from many broken weapons especially the axes which easily snapped off during transit which resulted in a lot of lost stock. So I decided to get the set redone to rectify the situation, the poses were changed to better support the weapons and so I have very few damaged sprues now also at the time I decided to add a riflemen squad for variety to mix up the stands a bit.
Set A is discontinued at this time although the mould is still available if I change my mind.
Set B is the only skinnerz regular infantry set available.
Hope that clears things up, set A bad, set B good. :)
Battlescene Designs
Wasteland Games Studio
PostPosted: Mon Feb 12, 2018 10:46 pm
Hi L4,
Hull length 27mm, hull width 17mm, height 10mm minus turrets approx, there is some variance between the different designs.
Battlescene Designs
PostPosted: Mon Feb 12, 2018 11:03 pm
Cool ! Thank you !
PostPosted: Thu Feb 15, 2018 8:06 am
More prints have arrived!
https://scontent.fams1-1.fna.fbcdn.net/ ... e=5B2586EA
PostPosted: Thu Feb 15, 2018 9:24 am
Who can spot some 3mm novan regulars ;)
Flickr|Flickr#2|Brickshefl
PostPosted: Thu Feb 15, 2018 3:27 pm
Always teasin'...
PostPosted: Thu Feb 15, 2018 3:42 pm
I've seen a few ;-)
6mm scale Scifi Plastic Sprues available here!
PostPosted: Fri Feb 16, 2018 5:14 am
Those prints looks awesome, large mutated horned metal warriors always good to see ;)
PostPosted: Sun Feb 18, 2018 3:14 pm
Does anyone know if there is a problem with the website at the moment? Am having trouble accessing.
PostPosted: Sun Feb 18, 2018 3:36 pm
http://downforeveryoneorjustme.com/vang ... ures.co.uk
http://downforeveryoneorjustme.com/www. ... ures.co.uk
not just you
