Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Tyranid 2014 Playtest Proposals
 Post subject: Re: Tyranid 2014 Playtest Proposals
PostPosted: Sun Dec 21, 2014 11:46 am
Quick answers, I am sure Dave will fill in soon.
1) A synapse formation can only swarm creatures that originally belonged to it, but is able to exceed the starting number. So, for a formation to swarm back gargoyles, you have to upgrade it with at least one gargoyle from the start. The same goes for termagants and hormagaunts. Many players field their basic swarms with 5 termagants and 1 hormagaunt, just to have a tactical decision as the battle progresses.
2) You can purchase an extra warrior to get swarming bonus. Then you swarm 2 inside 30 cm (always round up). Two swarms with extra warrior and the Dominatrix give you a very strong swarming phase. I also play assault style, and rarely have any gaunts in reserve after swarming.
3) You count the WE total.
As for gargoyles, their movement makes them much more useful than termagants, and if they were available as an instead of gargoyles, I would do as Dave and pick them every time.
/Fredmans
PostPosted: Sun Dec 21, 2014 12:15 pm
These playtest proposals have done away with the restriction of only being able to swarm units that were originally in the formation. Probably to do away with needing to take a single stand of each type with your Dominatrix for example - didn't really match the intent of the rule.
I've found taking the extra Tyranid Warrior to be very useful in bumping your swarming allowance up to 2 when you're up close with the enemy - almost to the point of it being an auto include. Particularly if you're using pairs of formations, one of which contains a Hive Tyrant so you can carry out combined assaults using the Commander ability - that's potentially an extra 4 bodies in a subsequent engagement which can make a big difference...
PostPosted: Sun Dec 21, 2014 1:13 pm
Cool beans, erase #1 then. Still, the effect of swarming on brood creatures purchased as part of independent formations should probably be clarified (gargoyles and raveners).
And I do agree with you. The extra swarming is probably the best one of all the synapse swarm upgrades.
/Fredmans
PostPosted: Sun Feb 01, 2015 12:54 am
How do people find fielding formations of Inf and only a few AV?
My initial concern is that unless I pimp out a swarm with 1 or 2 carnies then my tyrant just becomes a bullet magnet and essentially grants 'sniper' to all AT shots.
Jim
PostPosted: Mon Feb 02, 2015 2:16 pm
Agreed. On bare-bones swarms, I go with Warriors instead of Tyrants, to let them hide in the swarm.
PostPosted: Mon Feb 02, 2015 2:56 pm
Yeah, definitely. I wouldn't take a hive tyrant unless there are a couple of other AV units for it to hide behind.
PostPosted: Mon Feb 02, 2015 3:54 pm
Jim
Indeed other AV are needed for extra body count. They're still easier to take out (the opponent usually only needs 3 or 4 AT hits) than two seperate inf units so I also usually take an extra warrior unit in the formation to not loose synapse (and for the added bonus of an uneven amount of spawning points with rounding up).
PostPosted: Mon Feb 02, 2015 8:51 pm
Okay gents Thanks.
I'm a bit concerned about putting too much into one swarm and may just run them as inf heavy with separate av swarms to avoid the formation being essentially a light vehicle.
Cheers.
Jim
PostPosted: Tue Feb 03, 2015 12:13 am
Swarms from 300 to 350 is generally what I field. Mixed types.
Squats 2018-05-15
PostPosted: Tue Feb 03, 2015 12:23 am
Can you please post one of your lists Dave?
I'm struggling to know what is going to be an effective combo. I Need to get some playtesting done.
Jim
PostPosted: Tue Feb 03, 2015 10:45 am
In mixed swarms, I try to fit half as many AVs as INFs, in order to let the INFs get cover to-hit modifiers in the open (by cuddling up to the big bugs).
In regular engagement swarms, I waffle between Carnifexes (for Fearless) and Haruspexes (for a couple of decent short-range shooting attacks), and usually winds up taking a mix; Eg:
TYRANID SWARM (S) [300]
4 Termagants, 2 Hormagants, Hive Tyrant, Carnifex, Haruspex
or
TYRANID SWARM (S) [400]
4 Termagants, Hive Tyrant, 2 Hormagants, Tyranid Warriors, 2 Carnifex, Haruspex
A minimal INF swarm is also nice as a blitz guard; It can then sit in cover and swarm.
PostPosted: Tue Feb 03, 2015 9:18 pm
Okay great. Thanks StM!
That looks like a fairly balanced unit. With a good amount of spawning and some Mw attacks and some RA.
Haha I love the visual of the gaunts cuddling up the the AVs - but I guess that would be what it would look like... if aliens were real and all...
Jim
PostPosted: Tue Feb 03, 2015 9:42 pm
These are some of my typical swarms:
Code:
Two Tyranid Warriors, 4 Termagants, 2 Carnifex, 2 Hormagants
Two Tyranid Warriors, 4 Termagants, 4 Malefactor, 2 Hormagants
Two Tyranid Warriors, 4 Termagants, 2 Haruspex, 2 Hormagants
TYRANID SWARM (S) [250]
Two Tyranid Warriors, 4 Termagants, 2 Zoanthrope (745.M41), 2 Hormagants
Maybe with a Zoanthrope added here or there. The Tyrant would do good enough in most of them. The Malefactor one could even drop a Malefactor as the transport wouldn't be needed.
Squats 2018-05-15
PostPosted: Tue Feb 03, 2015 11:38 pm
Thanks Dave.
Sorry just to confirm - spawning allows you to exceed your starting unit strength or not?
I think ive read it both ways.
Jim
PostPosted: Wed Feb 04, 2015 1:30 pm
Yes you can go beyond starting strength :)
cheers
cron
