AMTL 3.25 (Approved)
 Post subject: AMTL 3.25 (Approved)
PostPosted: Mon Feb 27, 2017 6:02 pm
Changes:
Warlord Hull cost reduced to 675 points
Reaver Hull cost reduced to 550 points
Skitarii corvus restriction removed
Skitarii cost increased to 250 points.
AdMech0.93.pdf [1.53 MiB]
Downloaded 428 times
-Vaaish
 Post subject: Re: AMTL 3.25 (Approved)
PostPosted: Mon Feb 27, 2017 6:12 pm
nice one!
Someone should ping Kyuss to update Armyforge
PostPosted: Mon Feb 27, 2017 6:43 pm
Great news!
PostPosted: Tue Feb 28, 2017 2:32 pm
Fantastic!
Toronto Wargaming Group
PostPosted: Tue Feb 28, 2017 2:58 pm
Will sort armyforge shortly :)
PostPosted: Fri Sep 29, 2017 11:18 pm
Could you kindly tell me, wether
1) this is the same list as the one in the 2017 tournament pack
2) those changes are all the changes between this list and the 2016 tournament pack list
Thanks
Stephan
PostPosted: Fri Sep 29, 2017 11:22 pm
I'm not really familiar with what's in the TP myself. The list should be fairly similar since it hasn't changed structurally for maybe 5 or more years. Most likely there are points differences. If so, the PDF file at the start of this thread or the latest version of that PDF is what you should go by.
EDIT: it looks like the Tournament pack site is the same points as here.
-Vaaish
PostPosted: Sat Sep 30, 2017 8:49 am
Thank you Vaaish,
my army generator has all the stats and special rules.
If there is no list of changes I will have to check literally everything, turning a 5 minute job into an one hour job, prone to oversights. That's the major reason for a slow update cycle.
So I will have to check with the TP creator.
PostPosted: Sat Sep 30, 2017 2:25 pm
The last page of the PDF contains a changelog for each version. You can use that to see what's changed
-Vaaish
PostPosted: Sun Oct 01, 2017 1:05 am
I had looked only at the TP lists, which haven't got that appendix.
But there should be a github site which contains the change-log. I'll check that out.
Thanks again.
