Favourite armysize and rules for 15mm warhammer 40k
 Post subject: Favourite armysize and rules for 15mm warhammer 40k
PostPosted: Tue Feb 20, 2018 12:05 pm
Been inspired to start some 40k in 15mm. Thinking about starting with some small skirmish armies, just to get the painting started.
So many cool minis out there, and prices that wont cost you and arm and a leg.
What rule system for 15mm can you recommend? And have is there stats for 40k units?
I am a big fan of Too fat Lardies Chain of Command myself, but cant find a real scifi/40k conversion of it.
 Post subject: Re: Favourite armysize and rules for 15mm warhammer 40k
PostPosted: Tue Feb 20, 2018 1:20 pm
I play Bolt Action with both 28mm and 15mm. Works quite well. Maybe try Gates of Antares as I believe its similar to BA but with a Sci-fi flavor?
PostPosted: Tue Feb 20, 2018 1:58 pm
andyskinner used CoC with 15mm Quar. I don't know if he changed much rule-wise though, although the setting is sci-fi it's very WWI era flavored.
I've played GoA, it's decent enough and shares many mechanics with BA.
I haven't done an exhaustive search but there's no 40k lists/stats for them. You might be better off with a game with a points system where you can make your own. Off the top of my head:
Shockforce/Warengine
No Limits
Combat Zone
Stargrunt II
FAD (Fast and Dirty)
FUBAR
1-page rules
Squats 2018-05-15 | Raven Guard 2018-04-23
PostPosted: Tue Feb 20, 2018 4:32 pm
Beyond the gates of 40K is a BtGoA/40K mashup that you van find on the dakkadakka forum. I started my 15mm project after reading the rules.
PostPosted: Tue Feb 20, 2018 4:38 pm
Will you be using any of my figs? :-)
6mm scale Scifi Plastic Sprues available here!
PostPosted: Wed Feb 21, 2018 11:00 am
Thanks for all your tips. Have alot to look through. :)
Definitely!
PostPosted: Wed Feb 21, 2018 11:27 am
Definitely!
I'm not knowledgeable on the best rule systems for 15mm, but please do post pictures of your games. :-)
PostPosted: Wed Feb 21, 2018 2:18 pm
I'm using your exclusivly!
PostPosted: Wed Feb 21, 2018 4:22 pm
:spin :spin :spin
Thanks!
PostPosted: Sat Feb 24, 2018 4:06 am
Plenty of options for the 15mm line, suprised to see not many folks doing a 15mm space wreck project either , great minatures and Kudos to the designer ;)
