Post new topic Reply to topic  [ 333 posts ]  Go to page Previous  1 ... 19, 20, 21, 22, 23  Next
Nitpicks Knapsack - Nurgle, terrain and Titans!
 Post subject: Re: Nitpicks Knapsack - Nurgle, terrain and Crimsons!
PostPosted: Mon Feb 27, 2017 12:21 pm
Tack, mordoten. Looking forward to seeing those transporters painted...
My not so fast orky project log
Nitpicks KnapsackNurgle cult, Terrain, and the nostalgia of Crimson Fists
PostPosted: Mon Feb 27, 2017 2:15 pm
Love the colour palette - Great models!
PostPosted: Mon Feb 27, 2017 9:24 pm
Awesome!
PostPosted: Thu Aug 09, 2018 10:46 am
Long time no hobby. Had a good game the other day and got the bug again. Time for a break from the Nurglies, though. Time for some Epic Titans. True to form, I will be completely ignoring the biggified platinum casts from GW. Apart from the unwanted price/size/quality hike, I quite like the look of the Epic 40K Warlord. So, lets see if I can make this happen.
 Post subject: Nitpicks Knapsack - Nurgle, terrain and Crimsons!
PostPosted: Thu Aug 09, 2018 11:09 am
Work in progress. I just got my hands on blue stuff. This is truly epic. Makes replicating missing parts a breeze. Also handy to do molds of original parts (such as titan weapons) you intend to modify. I am making two-part molds to use for pressmolding a mix of milliput to get the hardness and filability and milliput to get strength. Works out well enough methinks.
I quickly found out that pressure is key...
PostPosted: Thu Aug 09, 2018 11:12 am
Some construction pics. Reaver and crusader robots.
PostPosted: Thu Aug 09, 2018 11:18 am
The merry familiy photo. Getting there.
Warhounds are to be repainted due to global warming.
Next: The tribulations of magnetizing, cleaning up, basing and, eventually hopefully, painting.
PostPosted: Thu Aug 09, 2018 5:44 pm
You got way better reasults that I got. I have to try miliput as well.
Flickr|Flickr#2|Brickshefl
PostPosted: Thu Aug 09, 2018 6:11 pm
Granted, crusaders are not the easiest of test objects. The awkward cavity at the chest did not work well. I could probably do better, but I am old and lazy, so these will do for now.
PostPosted: Thu Aug 09, 2018 6:18 pm
Magnets. I always wanted to need them. Because reasons. So I might have gone a bit overboard. All three battle titans have magnetized weapons, torsos and bases (for easy storage). This was a fiddly learning curve, but I am pleased with the results.
PostPosted: Thu Aug 09, 2018 6:34 pm
Bases. One of the most satisfying things with an army of big stuff is that the bases are also very big. Plenty space for dioramas. Mine is not a particularly original approach, but it was great fun. 4 more 60 mil bases to go! :P
PostPosted: Thu Aug 09, 2018 8:19 pm
Teach me how to do good push molds master.
PostPosted: Thu Aug 09, 2018 11:23 pm
Really, I am not an expert by any means. But here is how i did it more or less.
As with all molds, you need enough to cover the master and quite a lot more. I got 4 rods of it, which is barely enough for most epic minis and parts
You also need a smallish open box capable of sustaining some pressure from the inside. I used a thick plastic thing from a bits storage unit i got from a DIY. You also need a rigid ”lid” fitting into the inside of the box. This will keep the pressure applied uniformly counteracting skewed results.
Then immerse the stuff into boiling hot water. Dont underdo this. Really hot so that it is truly goey after about 3 minuters.
Take half of it to form the bortom half of the mold. Put it into the box and cover the bortom roughly evenly. Put the master on too and push it in halfways. Be attentive and make sure your moldline runs where it is suppose to to avoid too much messy clearing up. Use e.g. a brushhandle and push into corners to help align molds later. Let cool until completely rigid again. Takes a couple of minutes. Reheat remaining stuff and cover the master and bottom half. If you want you could apply pressure in this step to make the mold as detailed and dense as possible. I used a Clamp. I have not used a rigid enough lid to distribute pressure but it has worked alright most of the times....
Again allow to cool. Then take the mold out. This is a bit fiddly. I used a sculpting tool. Carefully pry the two halves apart and remove master. Add your medium to both halves of the mold. Carefully. This is important. Use a tool to get it into the tricky bits. Make sure you have a minimum of surplus medium. Too much will distort shape and cause massive cleanup...
Join filled mold and put into the box lid on top and then clamp dont overdo it, check box for signs of warping. Wait 3-4 hrs (for my mix of milliput and GS).
Et viola...
PostPosted: Fri Aug 10, 2018 12:43 pm
And a scratchbuilt Quake cannon. Felt like I should have one.
 Post subject: Re: Nitpicks Knapsack - Nurgle, terrain and Titans!
PostPosted: Sun Aug 12, 2018 8:09 am
Wow. Things have really gotten quiet around here...
I suppose I might as well post the last of the WIP pix I took yesterday. Reaver base. With feet.
