Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Necron playtest list for 2018
 Post subject: Re: Necron playtest list for 2013
PostPosted: Sun Jan 27, 2013 12:33 pm
Harvester engines do need some boost to compensate for the the down-grading of LM. If I remember correctly I think E-UK reduce their points and played around with some of the weapons.
I still think that the Aeonic Orb is still a bit of dead duck in their list but the Abbatoir is properly awesome and in bigger games I never leave home without one.
PostPosted: Sun Jan 27, 2013 5:14 pm
Small sample size, perhaps, but in my one big tournament Necrons were #2 and #3, and both had a different big harvester. There's also a 100 pts cost reduction in there.
Bottom line is that Harvesters are secondary to LM as an overall rule. First balance LM against Monoliths and Portals, then fix Harvesters.
PostPosted: Sun Jan 27, 2013 5:26 pm
Agreed. This is a very sensible approach.
PostPosted: Sun Jan 27, 2013 7:57 pm
From a fluff point of view I think it's bad to take away the lance-immunity. the 5th (4th?) edition necron codex which the current necron list is based on had living metal vehicles immune to those kind of weapons. I think removing that is overdoing it.
PostPosted: Sun Jan 27, 2013 8:03 pm
They were also immune to Multi-meltas and such, so if we're removing MW vulnerability Lance should also have full effect. (It's the 3rd Codex that the list is based on.)
edit: Old Living Metal is a very good translation of 40k Living Metal. The issues are a) Monoliths are perhaps too tough and b) the interactions between old LM and other rules/armies have some negative consequences as well as being very annoying for the opponent.
PostPosted: Tue Jan 29, 2013 6:19 am
if your going to make new lists are you going to make them based off new or old codexs?. I ask cus if your going to make them off old ones you should use the old rules for said problem(LM). But if your going to make em off new edition lists you should use the new rules. I dont think it should be mixing and matching rules and lists but I think leaving old rules for old lists and build(even if its slightly edited/updated) new rules for the new lists. Bace the raiders LM off of the 4th ed codex and leave it at that (the exact rules dosnt matter to me, just where you get the fluff/ how you think they should work ideas for the rule) I dont know if the LM rules will ever find that "perfect Balance" that fixes every thing and every one loves and works for every list to come, but make it work for THAT list atleast.
PostPosted: Tue Jan 29, 2013 10:11 am
Old lists only for me (including the Tomb World list). I got no interest in the new list - it doesn't mean I'll lock it down in a damp, dark basement and prevent any kind of new list lists to appear, but I'm not going to lead the work on it. I'll be happy to give any support I can give to anybody who wants to make one though.
Changing LM is about game balance and fairness, not fluff. Old LM matches up very well to 3rd ed 40k LM, but I've come to believe that the list would play better if it's changed.
PostPosted: Fri Feb 01, 2013 11:35 pm
Ulrik wrote:
Units made of living metal counts as having Reinforced Armor.
A unit with Living Metal that is hit by a Titan Killer attack gets a special 4+ save, even though Titan Killer hits normally don't allow a save.
A Living Metal War Engine rolls this save against each point of damage taken from a Titan Killer attack that does multiple points of damage.
Hi man! Some of the units in the new-codex-lists around here have units with the living metal rule but with a 5+ save. Perhaps you could rephrase the above, to something like:
...A unit with Living Metal that is hit by a Titan Killer attack gets to take it's save ones, even though Titan Killer hits normally don't allow a save...
Otherwise they'll get a better save against TK than MW
cheers
PostPosted: Sat Feb 02, 2013 12:56 am
LM 5+? Damn you kids and your modern ideas!
In my time, LM units had 4+ save with reroll against anything, and we liked it.
Which list, btw? It's not in Lord Aaron's list, and I have to admit I haven't looked at the others in quite a while (as Lord Aaron seems to be the only one that's activly working on a list).
PostPosted: Sat Feb 02, 2013 1:54 am
I think its a good idea, just to say - the saves gets a reroll against every thing, or some thing like that... I never thought that there was only a 4+ for LM. And as to why i don't have it in my list, I just don't think it should ever AV needs it, more reserved for the heavier vehicles.
PostPosted: Sat Feb 02, 2013 7:03 am
Oh I thought it was both lists, but it's only in BlackLegions list when I just doublechecked) I agree more with your aproach Lord Aron. I wouldn't put LM on the new Armored Vehicle units. Reinforced Armor seems a more appropriate representation of quantom shielding.
PostPosted: Tue Mar 05, 2013 3:47 pm
Hello gentlemen !
During nighttime i put some paint on my necron warriors, and soon or later i will field them ;D . Therefore i have been reading the posts (and concerns and comments) . For me :spin the LM discussion seems to have its origins in the fact that the monoliths are the key twoards the necron style of play.
What about the thought that portals can only be used when the formation is unbroken.
In this case there was to chance to keep LM like it is /like it was - in order to keep it that hard to kill something undead , but to reduce its potential quite a bit (in addition to the aspect of movement for free when broken)
regards stefan
PostPosted: Tue Mar 05, 2013 3:59 pm
right now it's WAY too easy to break a monolith formation..... if you pack enough disrupt weapons and macro, coupled with a high activation count that's almost an auto-win against necrons
pylons are already at the 'just break and ignore' level, I'd be wary of changing the status quo (and therefore the entire playstyle) so much
breaking them is still a useful thing to do as they can no longer prep + support fire to engagements which makes engaging much more risky for the necron player, I'd suggest limiting them to a single move when broken perhaps to avoid them 'withdrawing' into an inch perfect engagement position, but it's not too horrific atm, they're far from unbeatable as they are....
PostPosted: Tue Mar 05, 2013 4:10 pm
Yes, like Kyuss says it's very easy to break Monoliths if you want to. Also remember that as teleporters they often start with a BM, and unlike Terminators (who also suffer from low formation size and teleport BMs) they're very likely to activate only after the opponent has had a shot at breaking them. As the rules stand it's annoying for the opponent that breaking them doesn't do all that much, but if it shuts down portals it could potentially nerf the entire army.
Finally, the proposal at the table is to nerf Living Metal, which I think has a cascading effect on the army. I'm not going to add any other proposals until that is tested, so posting batreps with the new LM is much more useful than proposing new rule changes. This isn't just directed at you, Stefan, it's just me being a bit annoyed in general :)
PostPosted: Tue Mar 05, 2013 8:46 pm
I will try to get a game in.
Current Fan-made Epic Supplements
[url=http://www.tacticalwargames.net/resources/raiders2.zip]Epic: Raiders 2.0
Epic: Siege
Making your own Epic Supplement
Syncing Forward
