Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4, 5
Codex Astartes v2012
 Post subject: Re: Codex Astartes v2012
PostPosted: Fri Mar 04, 2016 1:59 pm
For tournament play? None right now approved but the Raven Guard list has them as a formation upgrade. They're currently in Development and could use help testing to go Approved.
Nothing stops you from using them in friendly play.
Thanks Jimmy. No just casual play, just wanted stats, points etc. ill check it out.
PostPosted: Thu Nov 10, 2016 2:27 pm
Hi guys,
Is there a list for AA that contains newer toys like Xiphon interceptor or Stormhawk?
I am Army Forge contributor, so if you need to add something or you have spotted a bug do not hesitate to contact me.
PostPosted: Thu Nov 10, 2016 2:53 pm
The Xipho is found in the heresy lists, mate. Go check the Index Astartes sticky post for links out to everything.
The Stormhawk isn't appreciably different in EA stats from a Stormtalon to really warrant inclusion. Basically rename Stormtalon with *hawk as you want and call it good for your head cannon if you need.
PostPosted: Thu Nov 10, 2016 9:22 pm
Uhm, following your advice. I was able to find the Xiphon in HH lists, however I also went through the NetEA lists (tournament and others) and no luck here. Could you point that out for me?
PostPosted: Fri Nov 11, 2016 2:02 am
Like I said, the Xiphon is in the HH lists being a weapon used back then.
PostPosted: Fri Nov 11, 2016 8:39 am
Yeah the heresy lists are separate from the NetEA lists, they are developed for different purposes
If you've managed to get some xiphon models then they will work as proxy thunderbolts/storm talons/nephilims just fine in the respective netEA lists....
[http://adam77.github.io/snapfire/war/]Army Forge[/url] List Co-ordinator
