Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
Imperial Guard units from Wh40k
 Post subject: Imperial Guard units from Wh40k
PostPosted: Fri Sep 17, 2010 8:48 pm
This thread is a collection of new Imperial Guard units as they appear in the new Codex Imperial Guard, the various Wh40k Apocalypse supplements and Imperial Armour books.
The stats and capabilites are interpreted from existing Epic: Armageddon units and my "Wh40k to Epic System" (from now on referred to as "WhES") with some tweaking of common sense.
This list also includes new interpretations of already existing units.
As always see this stats as a starting point from which actual developement of units for a variant armylist might occur and not as set in stone.
If any unit is capable to transport "X Infantry units" then it is capable of transporting ANY Imperial Guard unit which is of the Infantry type. Ogryn units use up two transport spaces each.
From Codex: Imperial Guard 5th Edition
Leman Russ Vanquisher
Armoured Vehicle 20cm 4+ 6+ 4+
Weapon Range Firepower Notes
Vanquisher Cannon 75cm AT2+ Macro-weapon
Lascannon 45cm AT5+ -
2 x Heavy Bolter 30cm AP5+ -
Notes: Reinforced Armour.
Leman Russ Eradicator
Eradicator Nova Cannon 30cm AP4+ Ignore Cover
Leman Russ Punisher
Punisher Gatling Cannon 30cm 3 x AP5+ -
Leman Russ Executioner
Executioner Plasma Cannon 30cm 3 x AP4+/AT4+ Slow-Firing
Leman Russ Exterminator
Exterminator Autocannon 45cm 2 x AP5+/AT6+ -
Banewolf
Armoured Vehicle 30cm 4+ 6+ 3+
Cemical Cannon 15cm AP2+ Ignore Cover
Devildog
Armoured Vehicle 30cm 4+ 6+ 4+
Melta Cannon 15cm MW5+ -
Notes: The Melta Cannon can shoot and be used to confer the macro-weapon ability to the unit's firefight value.
Colossus
Armoured Vehicle 20cm 5+ 6+ 6+
Colossus Siege Mortar 15-120cm 1BP Indirect Fire, Ignore Cover
Notes: Colossus Siege Mortar can only fire indirect..
Manticore Rocket Launcher
Storm Eagle Rockets 60cm D3BP Indirect Fire, Disrupt, Slow-Firing
Deathstrike Missile Launcher
Armoured Vehicle 20cm 4+ 6+ 6+
Deathstrike Missile Unlimited 15-480cm 8BP Macro-weapon, One-shot, Indirect Fire
Vakyrie
Armoured Vehicle 35cm 5+ 6+ 5+
Multilaser 45cm AP5+/AT6+ -
Twin Multiple Rocket Launcher 30cm AP4+ -
Notes: Skimmer, Scout, Transport (may carry two Infantry units)..
Vendetta
3 x Twin Lascannon 45cm AT4+ -
From GW's Wh40k Apocalypse Datasheet download section.
Banehammer
War Engine 15cm 4+ 6+ 4+
Tremor Cannon 60cm 1BP Disrupt, Fixed Forward Arc
Twin Heavy Bolter 30cm AP4+ Fixed Forward Arc
2 x Lascannon 45cm AT5+ Left/Right Fire Arc
2 x Twin Heavy Bolter 30cm AP4+ Left/Right Fire Arc
Damage Capacity 3. Critical Hit Effect: The Banhammer's magazine explodes. The Banehammer is destroyed, and any units within 5cm of the model suffer a hit on a D6 roll of 6.
Notes: Reinforced Armour. Transport (may carry two Ogryn or any five of the following units: Imperial Guard units: Supreme Commander, Commander, Infantry, Fire Support, Snipers).
Banesword
Banesword Quake Cannon 75cm 2BP Macro-weapon, Fixed Forward Arc
2 x Twin Heavy Flamer 15cm AP3+ Left/Right Fire Arc
Damage Capacity 3. Critical Hit Effect: The Banesword's magazine explodes. The Banesword is destroyed, and any units within 5cm of the model suffer a hit on a D6 roll of 6.
Doomhammer
Magma Cannon 60cm MW4+ Fixed Forward Arc
Damage Capacity 3. Critical Hit Effect: The Doomhammer's energy coil explodes. The Doomhammer is destroyed, and any units within 5cm of the model suffer a hit on a D6 roll of 6.
Notes: Reinforced Armour. Transport (may carry two Ogryn or any five of the following units: Imperial Guard units: Supreme Commander, Commander, Infantry, Fire Support, Snipers).[/quote]
Deathstrike Vortex Missile 15cm-Unlimited MW2+ Titan Killer (D6), One-shot, Indirect Fire
From Wh40k Apocalypse
Hellhammer
Hellhammer Cannon 30cm 2BP Disrupt, Ignore Cover, Fixed Forward Arc
Damage Capacity 3. Critical Hit Effect: The Hellhammer's magazine explodes. The Hellhammer is destroyed, and any units within 5cm of the model suffer a hit on a D6 roll of 6.
From Wh40k Apocalypse Reload
Stormlord
Vulcan Mega-Bolter 45cm 4 x AP3+/AT5+ Fixed Forward Arc
Twin Heavy Bolter 30cm AP4+ -
2 x Lascannon 45cm AT5+ -
Damage Capacity 3. Critical Hit Effect: The Stormlord's magazine explodes. The Stormlord is destroyed, and any units within 5cm of the model suffer a hit on a D6 roll of 6.
Notes: Reinforced Armour. Transport (may carry four Ogryn or any eight of the following units: Imperial Guard units: Supreme Commander, Commander, Infantry, Fire Support, Snipers).
