Advice on thinning bases
 Post subject: Advice on thinning bases
PostPosted: Fri May 04, 2012 6:56 pm
Can someone please advise on how to thin the mounts on early production EW troops (Jump infantry), the ones I have are over 1mm thick (some near 2mm).
Tks
 Post subject: Re: Advice on thinning bases
PostPosted: Fri May 04, 2012 7:27 pm
Use a metal file like you find at a Hardware store( or your garage or tool shed) ... I've done it with both Exodus Wars and DRM figures ... no problem !
PostPosted: Fri May 04, 2012 8:32 pm
Either that or a saw.
Or thicker bases. :P
Squats 2018-05-15
PostPosted: Fri May 04, 2012 9:49 pm
150 figures :(
PostPosted: Fri May 04, 2012 10:00 pm
I agree with L4 – big metal file, run the bases down it. I've filed down the bases of 100s of MWG 6mm figs, not that bad, just stick a film on at get to it.
PostPosted: Fri May 04, 2012 11:58 pm
pair of pliers with bicycle inner tube glued to the grips to protect the figure (most have relatively 2d plane), whilst running a bench sander. 1 model at time: done in minutes, not hours!
MoK's Painting Blog
Now Showing:
PostPosted: Sat May 05, 2012 1:00 am
How many figs did you shoot into the wall with that method MoK?
Squats 2018-05-15
PostPosted: Sat May 05, 2012 7:47 am
not as many as he branded into his fingertips i'm guessing.
still, it would be VERY fast
The Stygian Incident Demon Engines list
Chaos Titan List dev
Experiments with casting
Experiments in boardgame design
ToEG Chaos Engines
PostPosted: Sat May 05, 2012 9:12 am
zero casualties: the metal is so soft it only requires a gentle touch
MoK's Painting Blog
Now Showing:
PostPosted: Sat May 05, 2012 3:22 pm
CBFASI wrote:
150 figures :(
I did it ... didn't take as long as you may think ... and I did a little at a time ... like like a platoon size unit (40) ...
cron
