Beastmen list?
 Post subject: Beastmen list?
PostPosted: Mon Jan 02, 2017 3:04 pm
Dont know if some one have made a list allready, but seeing the Microworld concept art, the idea of a pure beastmen army sounds fun. viewtopic.php?p=603476#p603476
But when i think of beastmen the result becomes quite orkish - strong melee units, ramshackle vehicles. And doing an army just to use minis sounds a bit fruitless for me. Any one have any ideas for a list that would make it unique?
Only thought i have for a unit now is minotaur carried artillery - fast and mobile.
 Post subject: Re: Beastmen list?
PostPosted: Mon Jan 02, 2017 3:44 pm
i'd say go for it. It DOES sound fun. Let's try and coordinate a wee bit as we've got some beastmen units in the Penal List so I'd like to built synergy between the two whenever possible.
PostPosted: Mon Jan 02, 2017 6:56 pm
Cool. Like your penal list, a penal legion will probably be a project some time.
Think the list could easily be both chaos or imperium like, the chance of a planet of beastmen making their own army after the imperium became really racist, is big.
Thought a little more about units:
Maybe having the possibility of a very magic army, or just a normal physical one. Thinking leaders with psychic powers and maybe even expensive specialist infantry with psychic short range powers, hitting hard on targets with good armour.
Since the beastmen have been a part of the imperium for some time, they could borrow alot from IG/LatD list, but add new units since they had holes to fill in the army, and no way of getting the needed stuff. Like aircrafts, titans and tanks.
Thinking the dull witted minotaurs could be used both as a heavy infantry unit and as a beast of burden, carrying or dragging artillery. Artillery that is hard to take down in close combat could be new.
Since there are more centaurs then one would normaly have cavalry in the armies, they could be several types. Close combat specialists, anti armor weapons or highly mobile sniper teams.
PostPosted: Mon Jan 02, 2017 9:22 pm
One of the lost and the damned lists would probably work quite well with those beastmen models.
PostPosted: Sun Jan 08, 2017 6:09 pm
Tried to make quick list of beastmen and beastly allies.
Pretty sure i made a lot of mistakes in the calculations and unit sizes :)
edit: i can see i missed out a couple of characters, ill try to ad a new version later
Beastman army 01.pdf [155.7 KiB]
Downloaded 79 times
PostPosted: Sun Jan 08, 2017 9:45 pm
Just a note from your intro regarding Minotaurs: those are just the colloquial term for the very large Homo sapiens variatus specimens so you should be good. Basically those Ogryn like abhumans that have devolved into a beastman state.
PostPosted: Mon Jan 09, 2017 6:53 am
Cool. didnt know that, thanks
PostPosted: Wed Jan 18, 2017 6:59 pm
Corrected some of the mistakes in the first list.
Ill try to make a print and play army if i get the time in the weekend.
Beastman army 011.pdf [165.67 KiB]
Downloaded 77 times
